12V upgrade - will not run
mbrandl
Purchased 12V upgrade kit (alternator, harness and coil)
Tractor (8N) has great spark
Starts but will not take off running
Changed distributor already from all the way forward to all the way back.
(quoted from post at 14:18:35 09/29/17) Purchased 12V upgrade kit (alternator, harness and coil)
You'll have to do a more precise job on setting the timing than just moving the distributor around. If you don't have a timing light I suggest that you borrow one and get the timing set correctly and see if that helps.
Assuming you have a side distributor (do you?)
There is a bit more to setting the timing than " Changed distributor already from all the way forward to all the way back. "
And a 12 v conversion has nothing to do with changing the timing.
But means you've done that, start by setting the point gap, .025.
Once you set the point gap, then set the timing.
Where you trying to adjust the timing by ear? If so, you just learned something that many of us learned 40 years ago....it ain't gonna happen.
Remove the #1 spark plug. (removing all of them makes the job a bit easier) Ignition off, place your thumb over the #1 spark plug hole and crank slowly until compression is felt. Continue to crank the engine until you see the timing mark, 0* (top dead center) on the flywheel through the timing hole in the right side of the bell housing. Use chalk on the flywheel to exactly align the 4 degree mark with the pointer. Loosen the hold down bolt. Rotate the distributor housing counter clockwise until the points are closed. Put the cap on & double check the plug wires, 1-2-4-3, CCW. Then, remove the primary wire from the side of the distributor (or at the coil, whichever is easier) Put one lead of your VOM (set on resistance) on the stud on the side of the distributor & the other on the block or other good ground. Slowly turn the distributor. The needle will move as the points close & then open. Find the exact spot just as the points open & then tighten down the distributor.
Now check your work (and the dynamic timing) w/ a light.
If it won't idle below 500 rpm (400 is better) don't bother w/ a light.
If it idles ok, make 3 marks w/ chalk or white paint on the flywheel:
4*
10*
17*
Start the engine.
At idle, the light should flash & the marker should line up exactly at 4* if you did the static timing correctly.
If not, loosen the distributor & turn it until the marks line up. It should take very little adjustment.
Once you've got that done, increase the engine speed to 1200 rpms. The light should flash & the marker should line up w/ the 10* mark. Then, increase the rpms to 2000 & look for the marker to align w/ the 17* mark.
Close counts on the advanced timing. A degree or 2 either way is ok. But, no movement or 5* or more off means you have an advance weight problem. You don't adjust the distributor to fix that.
75 Tips
