134 engine compression
figuring 14.7 lbs for atmospheric pressure the z134 is 6.6.1 to 6.6X14.7 = 97.02 psi, hope this helps
Engine:
Manufacturer: Continental
Model: Z-134
Fuel: gasoline
Aspiration: natural
Cylinders: 4
Valves: -unknown-
Bore/Stroke: 3.312x3.875 inches [84 x 98 mm]
Displacement: 134 ci [2.2 L]
Power: 39 hp [29.1 kW]
Cooling: liquid
Compression: 6.6:1
Rated RPMs: 2200
Firing order: 1-3-4-2
Starter volts: 12
Oil capacity: 6 qts [5.7 L]
Sparkplug: Champion D-16
AC 85 S
Auto Lite BT-8
Sparkplug gap: 0.025
Point gap: 0.022
Intake valve clearance: 0.013 (hot)
Exhaust valve clearance: 0.013 (hot)
