robertd
the oil line that runs up to the rocker arms. I need to know how it comes out , and were i can buy a new line mine is broke. i could not find it in the manual
That line has a quad ring like seal on the lower end that seals in an oil galley in the block. You twist and pull to remove it. It can be very, very difficult to remove at times. It looks like a new line is available from New Holland(86531563) "$$$$$$"
They run about $25.00 at least the last one I bought at CNH did. Im sure someone here may even have a used one. If you have a hard time send me an e-mail its open I may have an extra
The orginal part # for the little oil tube that goes from the head to the rocker arm shaft is EAF6580A and was priced at about $5.00 from N.H.
Problem is that part has been replaced by # 86531523 and cost about $75.00
You can find used parts (see link below) or if your tube is split you "MAY" be able to have it brazed.
The tube is taken off by just twisting and pulling up on it at the same time.
There is a little seal that fits on the end of the tube and seals it in the head. part # EAA6594A and cost about $1.00
ROCKER ARM SHAFT INLET
