135 / 230 Diff Lock
country877
This may be way out in left field can a diff lock be transfered from a 135 to 230 by changing 1/2 housing but what is inside that I Wonder about I have a 135 diff lock I use on occasions when ditching with a off center rear blade it keeps from pulling the front of the tractor in to the hill and If you hold the opsite wheel the one in the ditch spins.When I use a rear scoop in the creek for gravel It will load more when diff lock is down I am about convenced myself to keep my 135 I found a about new 230 but no diff lock.I am willing to put cash into if can be changed
The ring gear carrier is different too. I am sure you could change enough parts to make the 230 have diff lock but you would be better off just finding one with it already installed. If you still want to go the switching route I would change the whole rear end assembly right at the back of the transmission.
