135 override on grade
Don Ober
My 135 appears to over ride the clutch when come down a small grade My 50 I
can use the trans to hold back but the135 will appear to try coasting it does
have the power amp , would that have anything to do with that/
If you are using it with the Multipower in low or it isnt working then that is normal. You only get engine braking in high Multipower (when its working properly).
