135 rims on TO30?
acaswell
Hey all, i've got a to-30 with 12.4x28 on 11" rims and one of them is rusted out and needs replaced. I was searching for replacements and came across a pair of 12.4x28 on 11" rims in good condition with weights that came off a massey ferguson 135 for the same price I could get one new tire and rim for the TO-30. Does anyone know if those would be a direct replacement? It appears the bolt patterns match but I couldn't find anything about offsets or other critical dimensions. Thanks in advance!
You didnt say if the rims from the 135 are the bolt loop type or the power adjust (rail) type. If the rims you found have the bolt loops your centers should work. If the
rims you found are the power adjust rims (rail rims) then you will need centers for them to make them fit.
