1365 cockshutt transmission fluid
B squared
Hello, Im the new owner of a very beaten 1365, Im trying to find out how much fluid the transmission holds, Ive put 16 litres into it so far and still showing nothing on the dipstick, scared to overfill it, any help would be appreciated, thank you
Thank you so much! Does this include the rear end? And on the 4x4 model is there fluid in the hubs inside the back tires? Like wet brakes? If so does this all fill at the same time? Thank you
Transmission and rear end. The drop boxes are seperate. Brakes aren't wet, they're on the axles just inside of the rear end housing in a dry space.
(quoted from post at 05:50:20 05/18/22) Transmission and rear end. The drop boxes are seperate. Brakes aren't wet, they're on the axles just inside of the rear end housing in a dry space.
Can you please tell me what the drop box is? Is there where the 4x4 shaft comes out? Thanks
