1370 Hydraulic remotes issue
Hello, I have a 1370 that i am having issues getting the hydraulic remotes to work. So last fall I had to replace the PTO shaft. The guy that was using this tractor some how stripped it out....dont ask me how. So i proceeded to follow the procedure to replace it and everything went fine. However, my remotes no longer work. To me it sounds like there is air in the system. It is making that sort of noise. I thought that it may have drained enough oil when I replaced the PTO shaft that the pump was able to get air into it. I spent most of the trying to bleed air from the flow divider and pump lines before the remote valve. I did seem to get a little air out and now I have 1 set of remotes working very slowly in one direction, but not the other. The PTO, power steering, brakes all work just fine. It is only the remotes that are struggling to operate. I have read that some guys have issues clogging the inlet screen in the sump, but it sounds like that takes out all systems, not just one. Any help would be greatly appreciated!
I have also recently discovered that if I hold the clutch in that I can get the remotes to work slowly at low idle. But that is it. I talked to the local dealer this morning and he told me to cap and plug the lines going back to the PTO, but that did not help.
