1370 injection pump removal
A 9/16 swivel socket will be your best friend, and a couple 3/8 drive extensions, Power swivels are a little nicer to work with. you will get it. If you have not, it is good practice to align all the timing marks before removal of pump. There were issues with the front damper rubber failing and the timing mark ring slipping so I would align the marks in the 1 1/4" inch plug right at the pump before removing.
