1370 problems
700KK
A friend was running his 1370 and hit the clutch to stop it started making sound similar to grinding gears. This sound is only heard when clutch is pressed or when in reverse, otherwise the tractor sounds and acts normal during operation, everything works like it is supposed to. It still shifts fine and does not grind going into gear. It feels like there is more than a normal vibration in the floorboard when idling. We recently had the bolts holding the clutch packs replaced because they sheared off. ive never seen something like this before. Any idea where to start looking? thanks.
Something has went through the planetary gears probably one of those three Allen head bolts that hold everything together, very bad deal it usually destroys everything in the drum, it will need to be split again to see/ or repair
