1370 split part 2
So all the clutches are delaminating . Including the trans axle which I pulled out and is waiting disassembly. I have seen in other post a mention about a thrust Washer update in the trans axle . Was wondering if anyone has info on this update . Thank you in advance.
I doubt you have a book, you will look a long time in there to find a ..transaxle.. Maybe you just decided you have better nomenclature than they do. You must mean ..differential.. Looks like you have a big job there. Keep everything extra clean during assembly, check clutch packs seals after assembly with air pressure and a rubber tipped gun when possible.
Yes you are correct differential. Work on another project with trans axle. So do you happen to know about the differential up date to this tractor. And does the book tell you how to test the seals? Thank you in advance.
