The main things would be cooling, air induction and fuel systems, cylinder heads, increased clutch disc's in power shift, ring and pinion, four gear diff., the number of brake disc and final drive sun gears. Rod.
Sounds like a 1570 is going to be a little bit more durable in the long run. Am I correct? Probably going to pull a 30 Ft field cultivator. Thanks
As you can see there were changes on the 1570 to handle the extra HP. With a 30 ft you will more than likely need that extra HP. A 1570 should handle it better. Rod.
