ncbeefjerky
Just picked up another farmall this one is a 140 serial number reads 45282 J K K from what I have found it should be a 1971 or so 45282 but what dose the J K K stand for or mean?
I believe that the J means it has a Rockford clutch. I believe the KK means that fourth gear in the transmission is a different gear from the regular
140?s. It gives the tractor a faster road gear ( 4th gear).
(quoted from post at 21:35:31 09/18/19) Just picked up another farmall this one is a 140 serial number reads 45282 J K K from what I have found it should be a 1971 or so 45282 but what dose the J K K stand for or mean?
Welcome! My understanding is there were 2 different clutches available on the 140. The serial plate provides the clutch information so you can be sure to have the proper clutch on hand before doing a rear split.
Thanks I thought it seemed geared higher, would this make it a little bit harder to shift dose not shift gears as smoothly as my Super A
(quoted from post at 07:39:17 09/19/19) Thanks I thought it seemed geared higher, would this make it a little bit harder to shift dose not shift gears as smoothly as my Super A
That may be a blessing in disguise. Early last year our 140 slipped out of gear and ran away into a tree.
I ended up replacing the radiator, hoses, generator, and the steering box keys. Of course, we straightened out the sheet metal as best as we could.
(quoted from post at 04:43:43 09/19/19)
Ouch ! where can I find the info in detail on the serial # and letters
I forget where I found the letter information but here is the serial number information.
http://www.tractordata.com/farm-tractors/004/6/5/4657-farmall-140.html
(quoted from post at 08:14:39 09/19/19)
I took a couple of pictures at the time.
The front bumper was removed due to the front grader blade we had on over the winter. Here are a couple of "after"pics.
My son's dog,Paris needs to get her tractor ride.
You did a nice job with the repair, love the dog, I am afraid this tractor bug has bitten me, work on them in my dreams, and get nothing done.
