1456 hydraulics
856 guy
I have a problem with hydraulics on a 1456. Outlets or 3 point don"t seem to work. Took the pump out, checked gear and key. Seemed fine. Took the cover off above PTO. Draft linkage seemed normal. Had good flow of oil while tractor was running right inside of the hole on the right. So I assume pump is working. Took out pressure valve but is not a normal cage valve. It is a rod with an O ring at the end of it. Never seen this before. 3 point also don"t go down and assume it won"t go up if I ever get it down. Any help would be appreciated!
