1456 question?
larryanderson
I have a mostly stock 1456 and have a 3LM turbo that is near new.Will the 3LM be a better choice.Also have a 450 headed pump bigger lines and injectors.No PTO so what whould H.P. gain approximately be? Thanks
RPM 2600 around stock.With the bigger pump and injectors the boost is 25lb but that turbo has a large volume of air ratio.
that turbo is hurting you . id say if you were running 3200 to 3500 would be ok . try a 3ld 279 or 305 that should get you 40lbs of boost. what do you have your timing set at . I have a new 305 if your interested send me a pm .
