1460 how can it be unpluged ?
TWL
While running oats,the rotor has completely pluged up.We can get it to move about 6 inches using a come a long on the rotor and having someone up turning the wrench on the rotor belt.
The seperator grate is droped as low as it can go.
Would any of you have any ideas how to get it unpluged.Thank you for any help.
After sitting over nite try it again.
We plugged one hard one evening and gave up on it that day.
Next day that plug rolled right out of there.
Another thing you can do is pull the pins on both ends of the concave and drop it down farther. This allows you to pull some of the slug out of there also.
Gary
Get a few broken hacksaw blades and start sawing on the oat straw. I had it happen once to me in wheat because my rotor belt broke. Thats what i ended up having to do.
Put the rotor in neutral start machine slow down rotor speed untill belt is at outer part of the rotor pully put rotor in low range and bump in and out with switch at alittle above idle worked for us most of the time.
I slugged my 1420 with some tall green stem beans in 2004.I ended up having to pull the concaves to get it all cleaned out.Lost about 2 hours.
