1486 front axle pivot pin
Needing to remove the front axle pivot pin. I know I have to remove the bolt that goes thru the saddle thru the pin in the front. I have removed several in 06 and 56 series but they had a pin that went thru the front of the saddle thru the axle and out the back of the saddle. Thoes tractors you just jacked up the tractor until the pin was loose and drove it out from the back thru the front. This tractor,1486, all I can see is the pin theu the front and nothing supporting it on the back of the axle, looks like just stuck in the axle. Can I just jack up the tractor , take out the retaining bolt and just pull out the pin? Is there a way to drive it out from the back?
(quoted from post at 18:21:32 04/16/15) Needing to remove the front axle pivot pin. I know I have to remove the bolt that goes thru the saddle thru the pin in the front. I have removed several in 06 and 56 series but they had a pin that went thru the front of the saddle thru the axle and out the back of the saddle. Thoes tractors you just jacked up the tractor until the pin was loose and drove it out from the back thru the front. This tractor,1486, all I can see is the pin theu the front and nothing supporting it on the back of the axle, looks like just stuck in the axle. Can I just jack up the tractor , take out the retaining bolt and just pull out the pin? Is there a way to drive it out from the back?
You need to remove the cylinder yoke to expose the back side of the axle pivot pin.
