14t knotter not tripping
rasento
My new to me 14t ties well when I trip by hand, but the measuring wheel doesn't trip. It misses the target.
It looks like I could bend the arm that rides on the cam so it hits lower, but I can't believe that's really the problem. Any thoughts?
Video.
It's been awhile since I worked on one of those but I think the L shaped rod resting on top of the knotted gear needs to be straightened so it's closer to 90 degrees from the upright part of it.
Video.
Do you have an Operator's Manual, most adjustments are detailed there. I looks to me like an earlier 14T, I am more familiar with the later versions and the 24T and later balers so I can't offer any specific help.
You should be able to view for FREE or DOWNLOAD or PURCHASE a copy of the Operator's Manual at https://techpubs.deere.com/en-us/Search/Equipment
It takes a little finesse with the drop-down menus to download the FREE version, but it should be possible to do it, Parts and Tech Manuals are NOT free.
Finger Lakes hay equipment in NY has Manuals and LOTS of parts cheap for the JD balers. Very knowledgeable guys. Have tune up kits and tricks.Their number is at my shop. Will try and get it for you next week.
I bent the rod and now it trips, continuously. Every stroke of the baler. I consider it sn improvement, but it needs some more adjustments.
Would Anybody baling with an older 14t be willing to post a video of it tripping? I can't find a manual with this version.
585-526-6705. They do have a lot of experience with the older JD small square baler. Best to reach them M-F.
I think flat part needs to drop down about 1'' & then it will push spring loaded trip lever forward. I downloaded the only 14T operators manual listed on JD's OM site but it doesn't show this old of measuring wheel & mechanism.
There were 2 adjustments on mine. One adjustment tripped the knotted and the other one reset it for the next bale. It's been 35 years since I worked on that baler.
If it is tying continuously, the metering wheel is out of the picture. Something is preventing the clutch from releasing..... a tight lever or bell crank on a pin, or a broken spring to retract any linkage related to the clutch.
Since that top arm was bent, that suggests something fell on the baler and bent it. These do not just go out of adjustment. There may be other damaged linkage related to clutch operation.
I appreciate the feedback.
Now that i bent the round bar, The flat bar that TX jim put the x on can't get out of the way of the trip bearing until the star has rotated a significant amount to rotate the bell crank, but the bale doesn't move that fast. Because the bar is still there, it trips on every stroke.
I'm missing something like the second adjustment ET mentioned so the bar doesn't immediately block the bearing. Im guessing it needs to drop below the bearing before it finishes the knotters finish the cycle.
On the few facebook videos that show the early design, it doesn't look like the round bar rides on the high part of the cam like mine does, but that high part is there for a reason
I called FLH, but missed them. I don't want to do any more adjusting until I know what I'm doing.
  • Like
Reactions: ET
I'm messing with The round rod that rides on the intermittent gear. Since I can't find a manual showing this design, I've been looking for pictures on the internet. Every picture I've been able to find on the internet shows it on the lower part of the gear. When I started out, my rod was on Mine was on the small higher part (orange circle). I also noticed that most were straight after the last 90 degree bend, Mine had a little bend up (at the yellow circle). My thinking was that was why it was skipping over the bearing on the trip dog.
Since I can't find a manual, referencing this old design, I looked for pictures on the internet. All mine below and the ones ET posted show it on the lower surface.
So I bent it last night. But now it wedges between the upper and lower surfaces of the intermittent gear when the measuring wheel turns (between the red arrows). I was wondering if the intermittent gear is out of time so that upper part should be further away from the camera, but the knotters are working well, I don't want to mess with the timing. The previous picture shows one even lower than mine. My next though was to bend it so it's more like the angle shown by the orange lines. the picture below is my baler as of today. It takes a lot to bend this thing. I agree with the person who commented earlier that somethign drastic must have happened to this (or somebody was messing with it)
The manual that FLHE had was the newer style. He has not worked on the old version for a while. So he didn't have any suggestions. I didn't consider ebay. I'd have to ask them to check what version they had...
Work and vacation are killing me. Hopefully i can get to it next week. Although I may consider the burning option...
  • Like
Reactions: ET
I messed with the round rod some more and decided as others have said that bending it isn't the answer. It still gets bound in the intermittent gear. I really want to rotate the top of the intermittent gear to the front of the baler to give more room for the round rod. I don't see any way to do that in the manual. Im guessing its keyed to the shaft. There's a square set screw on the trip dog. Any idea what that's for?
I haven't wanted to mess with the timing, because it ties fairly well when tripped. I did find that the bevel gears are two teeth out of time. I think that only affects feeder teeth? I guess im lucky nothing crashed. I don't see how to fix that in the manual. Can anyone help with how to do that? I hope i don't have to take everything apart.
