I picked up a 14t last year and am going through it. I'm starting with zero understanding of balers.
The worst problem is that the plunger has worn a slot through the bottom of the bale chamber on the left side. I think I'm going to fabricate the whole bottom piece of sheet metal rather than try to weld in scabs.
My issue is why this happened and how to prevent it from happening again. There is an inch wide groove worn along the right hand vertical wear strip and knife on the plunger. Things were not aligned properly I'm not sure if they didn't have the plunger clearance properly adjusted or the problem with the bottom caused that.
My uncle gave me a parts list that shows a flat wear strip for the left side with a notch in it for the plunger stop. I don't see any holes in the bottom of the chamber to mount it. There also doesn't seem to be anything replaceable on that side of the plunger.
Anybody remember what the chamber looks like on your 14t? Is there a wear strip on the left hand side with a notch in it (#30 on parts list)?
Baler serial number is 21316
