I dont think it makes any difference.I have some on both but cant tell much difference except you may need to run different air pressure.
It seems like every set of tires is different.I would start at about 11LBS and then look at your tracks when you spin out.If your tracks look flat in the bottomof hole you are about right.If they are humped up in middel you need more air.If they are U shaped you have to much air.The link of the sled chain can make a difference also if you pull on more then one sled.Hpoes this answer your question.If not call me 618 664 2732 ask for Leroy
