1500 hydraulic trans filter
Status
Not open for further replies.
glenjbsg-HT
Hello i removed my filter from my 1500d not sure which way it goes back in as its a long cylinder with one end open and the other with a mesh covering.When i removed it the open end was at the end where i removed the housing .But my mate has one also and when he did his it was the opposite way so which way is correct
An easy mistake for your mate to make -- not even the factory operators/parts manual shows which way it goes, at least for mine.
Hoye sells a similar mesh item as a fuel-tank filter, to prevent dropping things in. Obviously, the closed end goes in first. The hyd mesh filter works the same.
Status
