(quoted from post at 14:35:46 11/25/09)
(quoted from post at 01:04:35 11/25/09) this tractor was bought new by the father of the person that I bought it from. He said the loader has been on it as long as he can remember. I had a 1/2" hose long enough to replace the pressure line to the control valve, I put it on this evening and it seemed to make the loader lift a little faster, but I can hear a hissing sound in the control valve now. I don't know how to tell if the valve is open or closed center though
1.) READ what TxJim said...
2.) READ what I said... I also already explained how you can tell if there is a problem at the valve.
But, let me repeat in really simple terms... Take the outlet (return) line from the valve (remove hose from the tractor end) and put it in a 5 gallon bucket (or what have you). Start the tractor up. There should be NO fluid going into the bucket.
If there is fluid flowing into the bucket, then you have found your problem! Your control valve is either blown internally, or it is the incorrect valve (open center instead of closed) for use with that tractor.
If the valve is more "modern" and it is a "convertible" valve, then there will be a big hex headed plug on the side of the valve. (Do not confuse this with the smaller hex plug that is near one of the spools. That is a pressure control valve. Don't mess with that.)
Remove that big hex plug and look at it. If it is a solid plug that goes into the port and blocks off the internal ports, which prevents fluid flow to the return, then that is a closed center plug.
If the plug is really short, or more likely long but has passages/ports drilled through it, then it is an open center plug, which is wrong for your tractor application.
The beauty of this setup is that you can change the plugs based on your application. Thus, the reason some control valves are called "convertible" control valves.
Honestly, something is starting to tell me that your problem is not the loader control valve, but I am not there in person doing the tests, so I just don't know.
We still need you to do what we asked, which is find out if that loader valve is flowing out any fluid from the outlet/return hose or not when the tractor is running, and you aren't messing with any of the controls.
The loader control valve being the culprit is merely a starting point that I went to based upon your earlier posted information about how you disconnected the loader valve and the pump noise stopped.
Any chance you can take some pictures of the valve (from several different angles) and post them? That would be helpful for finding out which type of valve you have.
Try removing the loader control valve from the system and when the pump noise stops, and see if your tractor will lift that motor/tranny with the 3pt hitch.
Before disconnecting the loader valve though, you need to put the loader up some (bucket about 3ft - 4ft from the ground), and place 2 pieces of angle iron on the lift cylinders, each to be held in place with at least 2 hose clamps on each cylinder around the rod end of the cylinders. Then you can "relax" the loader down on the "supports" that you just made and there won't be any pressure on the inlet and outlet hydraulic lines for when you want to re-connect it.
AND the loader will be "up" in the air some so that you can still drive the tractor around without the bucket dragging on the ground.
Then go try lifting up something with your 3pt hitch, such as a plow, pallet forks, a brush-hog mower, your 440 motor, or whatever you can find that is "standard" for use with a 1520 tractor. See how it reacts. I find it extremely difficult to believe that your tractor won't pick up a plain 'ol V-8 motor and tranny, without there being something seriously wrong with the hydraulic system on that tractor.
