1530 injection pump removal
Merton
Location
Washington NC
I'm having a problem removing the injection pump from my 1530. I have disconnected all the lines and removed all nuts. but it wont slide back on the shaft. It has moved back about 1/8 inch and wont slide back any more. Has anybody had this problem and what did you do to get it to remove?
i believe the 1530 was made in our German factory,, if it has the CAV pump, then i think i remember you have to remove the bottom radiator hose, then remove the small plate on the front of timing cover,, then remove the bolts from the timing gear, mark the flange on the pump housing for timing it back. a ROOSA,/ STANADYNE pump slides off the drive shaft..
