1550 carburetor
farmerwithmutt
Recently put in a new marvel schebler carburetor and for some odd
reason when you go to open it up it acts like it's not getting enough
gas. Went through the electrical and that's all new and ok. When we
looked at the carburetor one guy raised the question if it's the
correct power needle in the carburetor . The old carburetor that came
off was a zenith. The opening at the top of the needle is roughly the
size of a paper clip. We don't have any 1550 around to compare it to
and the 1600 and 1650 use different carburetor. What gets even more
interesting is when you look up its usually the same carburetor as a
550. When you try an adjust the needle you have very few turns to make
any kind of adjustments . Any suggestions would be appreciated thanks
The number on the bill of sale is 203358. I'll go out tomorrow and see if I can find a number on the carb.the number is a replacement for tsx 903 . I've seen a few post where they have drilled them out but like to wait and double check for sure. I'm not sure if other power needle would fit there .
