Finally getting to replace the axle seals on the 1555, I have a little end play on axle. If I remove a 007 shim it is almost gone. Is the axle bearing to be preloaded slightly.I reinstalled the .007 and removed a .015 and play is gone. Best to have slight end play or reload bearing slightly.
The other question is while apart I noticed the wheel hub is cracked pretty bad. I thought of welding it but figured just try and find one.that seams harder than I though.The casting number is 161806a. Is there another model tractor that may fit ? The hub has the 9 hole pattern I'm finding on the internet plus 4 larger bolts as well. The axle size is 2 58 with 3 ubolts holding it to axle.
thx Jake
thx Jake
