1570 brake issues
WHess
question for 1370Rod and others, Steering and Power shift work fine, but have lost brake pedal .brakes work good just have to pump the pedal several times .have bled but problem returns .remember last fall remotes seemed to hesitate on occasion. Brake cylinders leaking? What are your thoughts? Thanks, Wayne
If the brakes work normal after bleeding and the problem returns in a short time the most common place for air to enter is up in the brake valve. It was not to uncommon for that to happen if the tractor sat unused for sometime like over winter. Rod.
