1570 differential
1570 case
where does the diff line go into the rearend from the valve by the brake pedals? I want to block it off and see if I have a diff problem or my valve is sticking. sometimes it locks in by itself.
The easiest spot to disconnect it is remove the supply line on the flow divider valve. Its the smallest line on the valve, would have to remove line and cap the fitting on the valve. I have not seen a diff lock engage its self. You could put something under the engagement button to make sure it does not get accidently pushed down. I have a 1270 doing the same thing this spring, turned out to be differential problems. Rod.
On my 2096 the diff lock dont work I replaced the rocker switch because it was locked solid. Where should I look next? any ideals?
