My son and I got a 1586 International at a real good price because the engine was locked up in it. They had just spent a bunch of money on the rear end and they kept up maintenance on it.
We took it apart and found that it had spun rod bearings, more than likely from antifreeze getting into the oil somewhere since we found some when we drained the oil.
I'm splitting the tractor since the crank is toast. I've already bought a STD/STD crank from the local salvage place.
I know the engine is gonna have metal in it from the oil. I guess I need to clean out the oil filter housing along with new filters, the oil cooler will need flushed, the block will need cleaned, and what else? Can I disassemble the oil pump to clean it up for reuse?
The sleeves have almost no wear and the pistons look good. I think I'll go back with an engine kit. I'll have the crankshaft checked and rods resized.
Might as well completely disassemble the engine and take it in for a hot dip at the machinist...I don't think I can flush the oil passages in place, prolly not a good idea anyway.
What about the injection pump, I guess the drive gear is the only thing exposed to engine oil.
Have I got it all covered?
I've rebuilt several diesel engines including Deere, Mercedes truck engines, but mostly older Caterpillar engines.
I've still got to find out where the antifreeze got in the oil.
