16" Inner Tube
From what I can tell, it looks like the 218 has a bolt-in valve stem and the 15 just slips in? Or is there more to it than that? Just want to be sure I get the correct one.
Thank you sir!
TR15 is a rubber stem molded into the tube and fits a 5/8 rim hole, commonly found on tractor fronts and implement tire rims. The TR218A stem is the type used for adding liquid ballast into tubes. It is mostly metal other than where the metal is molded into the rubber molding of the tube. You would use that type if you needed to ballast a tire such as a front tire on a tractor to increase front end weight.
Like the TR15, the TR13 is the common stem on tubes used with the 1/2"rim holes, mostly used on automotive rims.
