I bought a reconditioned 1610D 2 years ago. It immediately blew a head gasket. Had bubbling water in the radiator fill neck. Tractor ran fine but would end up pressuring the radiator and catch can. Replaced the head gasket and put 200 hrs on the tractor. The other day I parked the tractor for a minute after some work and fired it back up. Started running rough. From idle to high revs it ran rough. Let it cool down and popped the radiator cap and had major bubbles and rusty water. No coolant in oil and no oil in coolant. Tore it down, cleaned head and engine deck. Checked it all with machines flat bar. Cylinders looked good. I had one out of 11 head bolts that looked like it got hot, the rest looked the same with oil on them. Put it all together and fired it up and it ran rough. Though it was fuel needing purged the fuel lines and didn’t fix it. Had cap off radiator the whole time and no major bubbles just turbulence from water pump. After a few minutes the motor did not smooth out and started getting big bubbles and rusty water come up at radiator. I’m so frustrated. Any suggestions? Can an issue in the block or internal crack in the head cause this? Anyone been here? I’m so disheartened . Thanks
