1630.. how to add another remote?
Pawel
Hey all.. any help whatsoever is appreciated.
I have a 1630 JD, with a single remote that I want to add another one to. I went to a wreckers and got another single remote that the wrecker claims will "bolt right on" but I have no idea how.
any ideas?
thanks.
The factory second remote looks similar but the handle inserts on opposite side of valve and has an extra two binds in it. The plate that the return hose goes on has to be R&R on your old valve and new valve is bolted to old valve with longer bolts. The two plug-in brackets aren't alike and the lines are not the same. The four plug-in lines are nearly like a jig-saw puzzle to install . Its been over 20 yrs since I since I converted one and I going off my memory.
completed it today.. i just reversed the lever and bolted her right up to the existing one with longer bolts.. works good on my baler.. thanks alot for the info.. God bless
