Glennmackenzie
Hi all,
After sorting through many issues with the 1640 (thanks Tx Jim!) I finally got everything sorted, however I just replaced a damaged brake line on the right hand side and while bleeding the system the oil stopped flowing just as I seemed to be getting the last of the air out and the pedal went to the floor. It appears the system ran out of available oil as now there are no air bubbles or oil coming from the bleed screw. My question is, what supplies the oil and is there a reservoir somewhere to check or does it just fill with the engine running? Everything was working fine before I replaced the damaged fitting. Had engine running for a while but still appears to be no oil available to the brake pedals
Any help is most appreciated, thanks!
