Recently bought my first Massey - a 1966 Model 165 - but it has loose steering. It appears the valve actuator is way out of adjustment.
I need to make a tapered pin adjustment (similar to the 65) for valve actuation travel. The valve actuation link ends and pins appear to all be tight.
The tapered pin has a lock nut with a slotted top to adjust it. Problem is the pin threads are seized up tight. Looks like previous owner used channel locks on it and still did not get it loose. It is soaking in penetrating oil now.
I plan to purchase a "drag link socket" which is just a large screwdriver that connects to a ratchet. I am thinking of pulling the entire link out to make it easier to work on, which means I have to remove a ball joint on the steering linkage (the rod from the steering wheel, going to the front along the left side of the tractor.) This ball joint also has a slotted screw and seems to be threaded into the linkage. I am not used to that kind of connection.
My question is . . . to remove the ball joint, do I just rotate the ball joint screw to get it out? Righty tighty/lefty loosey?
