1650 3-point
kevinecwi
I'm disassembling the hydraulic on my 1650 to install a new pump. I removed the top cover off the hydraulic housing and discovered that the dash pot piston has popped out of its bore, the pin that limits the dash pot piston travel is also bent but the spring was still in place. What could cause this to happen? The 3-point worked normally in my opinion, although I probably didn't have any draft control.
