The left brake cover has had a small leak for a year or so. Yesterday I was clearing some of the ice we got. I got off to angle the blade and saw quite a bit of oil running off of the battery box back corner. When I shut the engine off it quit leaking. Level was normal and clean looking. I pulled plate around the shifter and it was dry under there so the oil is coming from the side. I have the tires set in and 18.4x34 so it will be fun getting to the brake area.
What do you use to put the seal in straight? I did that several years ago but old age is setting in. I have not found anything I might have used for that around here. Might have to move the tires out too. That will be fun.
