What are the signs that indicate a distributor is past its prime? Still fighting an issue with my 1650 gas. Just wondering what the symptoms are for a bad Holley?
First it was starting to periodically stumble while in use, then it progressed to not being able to start it or keep it running once started. Put in a new dist cap, coil, set points, and gapped plugs and it was running great. Not even one pass cutting hay tonight and it crapped out again and wouldn't start/stay running. Gas at carb and carb has been cleaned. The way it cuts out and then won't even fire points me to something in the ignition, but the only thing remaining is the Holley dist.
