1650 Hydrapower fitting
codyw
The fitting in the center of the picture is leaking slowly while tractor is running. My question is how do I tighten it up? Is this threaded in or pressed in some how? I'd like to stop the leak but not sure how thanks.
I believe there's an o-ring around that inner part and that it's only accessible from the inside.
My 1550 is leaking there, too. That round piece is sealed with an O-ring and the side cover needs to come off to fix it. I cleaned it good as I can with carb spray and used a small screwdriver to force some blue silicone in around it. Temporary fix but it leaks a lot less and I eep an eye on the fluid level.
