You will need the Oliver/Waukesha specific pump, and there were two used on the 1650 depending if it's the early energy cell head, or late direct injection head.Thanks. Is there other combines/tractors that use the Roosa Master pump that would work? This tractor has no pump to rebuild so looking for a replacement.
The late direct injection head has pencil injectors.Hi Dieseltech:
From what is left of the serial number this unit is a 1967 second generation tractor. Would that make it a late direct injection head?
Is there a second place to find the serial number?
Hi tom upton: Thanks for the alternatives. You are right about the unknown. From what I know the tractor was running OK before the pump was removed. With a list of optional source of alternative I hope to pick up a test unit to see if I am right. So thanks for the list
The goal is to see if the tractor is worth fixing or should I just scrap it. I am more on the side of fixing but do not want to invest a lot of dollars to find out it is a scrapper tractor.
Hi: Yes the tractor does have pencil injectors. Thanks.The late direct injection head has pencil injectors.
The 310/283 pump will work just to see if the engine is good, the max fuel setting is the main difference on the 310 pump.Hi: Yes the tractor does have pencil injectors. Thanks.
Now that I know that the tractor has direct injection does it mean that any 310 engine should work to test if the 1650 will run or do I need to adjust the pump before trying to start the 1650 tractor? The goal is to see if the tractor runs and is worth fixing.
The lo/hi engine speeds are the same on both direct injected engines.Thanks Dieseltech. Since I also have a 1750 tractor I could use the pump off it to test the 1650 as long as I do not try high rpm's.
