1650 oil leaks
86ontherez
I have a 1650 with an oil leak out of the single speed PTO. Is there a seal with the bearing in behind the shaft? I also have a leak out of the left hand brake. Does the whole brake assembly come off to reveal the seal? Any help would be appreciated. TIA
Re brake leak: yes you can do this. Ross the Oliver man, and Chris the Oliver Man, I think both have U Tube videos on this job. Not to bad. Getting old seal out your main problem. Re: PTO seal, others can better advise you on that.
