1650 stack weights
relink
I have a 1650 with the starter weight already on it and I just purchased 2 more stack weights for it. My question is how do I bolt the 2 new stack weights to the starter weight?
A long bolt that attaches the stack weight to the base weight. The reason there are 2 holes in the stack weight is so when you put another weight on you use the other hole to attach the second one.
(quoted from post at 20:04:19 03/05/19) A long bolt that attaches the stack weight to the base weight. The reason there are 2 holes in the stack weight is so when you put another weight on you use the other hole to attach the second one.
So this time I just use 1 long bolt to hold them on and if I should add more weights in the future I can use the other hole with a longer bolt. Correct?
If I remember right you need 7 inch long 3/8 bolts. The
recesses cast in the bottom of the weights are shaped to trap
square nuts so if you can get your hands on some that will
make life easier.
