1655 Clutch replacement
pd143
I am going to start the the clutch replacement on my 1655. I would like some input into what else could use checking or replacement once the engine is out. Thanks
Always a good idea to do the rear main seal. There are several clutches available. I put a heavy duty 6 pad clutch in mine.
Josh
Among the other stuff mentioned, check the spline wear on the end of the pto drive shaft and the hub/plate that drives it. Other seals to check: front and rear on 2 or 3 speed, if equipped, and the trans input shaft.
