1660 combine wiring
MARK ROBKE
Hey,would anyone have a wiring diagram for a 1660 that they could scan and e mail or print out? I would appreciate it,thanks.Mark
Have you got a local dealer who might help? I was working on wiring in the same area(along the feeder house, for the header height control) this summer, and the local service manager was kind enough to e-mail wiring schematics.
What problems are you having with the reel? My 1680 reel would intermittently stop. Then it stopped completely. I traced the fault to a bad ground on the feeder house. That is where I would start looking. Pull the side panel of L/H side of the feeder hose. You'll find power and ground wires going to the electric/hydraulic flow/speed control valve for the reel speed. If you have power there you should be good. Mine grounded back on the top side of the feeder house....rusty loose bolt! I can't remember if it was factory ground wire or had already been worked on before.
We were working on the header height control,and the reel was working.As we went thru our checking and adjusting of everything for that,somewhere along the line the reel quit.We do know about the ground on the feeder house,but I suspect we disturbed or broke a wire while continuity checking the height control wiring.We searched,but did not find anything obvious yet for the reel-just hoping someone has a troubleshooting tree,or a diagram.Thanks,Mark,
