170 allis cab
Jeff 170
Will a 200 Allis Year Around cab fit on my 170 open station ? Also i have a loose steering sector. Does anyone have a repair for this ? A new one is $730 dollars ! Its loose on the gear not tie rods.
Any cab from a 200 will NOT fit a One-Seventy tractor. If the swing arm is loose on the steering output shaft, remove the swing arm, replace the shaft seal, reinstall the swing arm and weld it to the shaft on the bottom. The arm hole is worn and the shaft splines are worn.
