1710 ford leaking under shift boot ?
dave404
my neighbor called and said his japan ford (think its a 1710) is leakin hydraulic fluid from under the shifter boot.
I assume the plate must be removed ? and does it have a seal under the plate and where can I buy one ?
thanks, I will chk the vent and fluid level. is there a seal or something under the shifter ? I cant find anything through the parts department.
(quoted from post at 18:44:17 09/01/16) thanks, I will chk the vent and fluid level. is there a seal or something under the shifter ? I cant find anything through the parts department.
Parts page shows rubber seal, quantity two, under the cover. Part no. 41. My 960 was missing a similar seal and it would push the oil up and out.
http://partstore.agriculture.newholland.com/us/AlmaTractorEquipmentInc/parts-search.html#epc::mr56742ar396945bi2413425-41
can someone tell me if #41 on the above diagram are the 2 seals I need. I haven't removed the shift cover yet.
the vent was plugged tight, I cleaned it good and neighbor hasn't worked it yet. may fixed it, will know soon .
