1710 hydraulics
Diehard
I have a 1710 and would like to add the auxiliary hydraulic valve to the side of tractor under the seat. Anyone have that part or info ? Thanks !
Easy to add a generic valve. Maybe not as "pretty" as the OEM remotes but lots less expensive. You can get a three spool valve for well under $200 and a single spool for under $100. Just need to find a convenient spot to stick it then run a few hoses.
Dan
Run hoses where ?
Iwas in a rush when I replied yesterday. Heres a bit more detail.
First you need to purchase a valve with both power beyond and tank outlets.
Now go to the hydraulic block that supplies the loader. Its on the side of the engine andthere are three ports with hoses
Top left hose is the power beyond port from the loader. Disconnect that hose and move it to the P port on your new valve. You may need a longer hose.
Next connect the power beyond port on your new valve to the power beyond port on the hydraulic block. That completes the power beyond loop.
Lastly you need a tank return for the new valve. The lower middle port on the hydraulic block is the tank return for the loader. Disconnect that hose, install a tee, and reconnect the loader hose. Now connect the T port on your new valve to the tee on the hydraulic block. The loader and new aux valve are now sharing that port.
All done and ready for use.
Dan
