JWA
- Location
- Somerville,TN
The governor on my 841, 172CI is acting erratic. If I advance the throttle from idle to mid range 1000-1500 rpm the governor is constantly hunting. If I advance the throttle to the WOT position it runs fine and if I back down to mid range from WOT it runs fine with no hunting. I have gone through the linkage set up procedure in the manual twice and everything looks good. They do mention that erratic operation can be caused by a loose crankshaft hub, they specify 100ft.lbs. I'm going to tighten it some more today hope it helps. Anybody out there got any other suggestions? Engine was just built and governor operated fine before. Thanks Bill
