1734e with CB75 backhoe - sway control?
Bodo
Howdy gang
When the backhoe subframe was installed, it moved the 3-pt sway control from outboard to inboard. The stock adjusters don't work anymore because:
1) The tabs impact the arms.
2) The adjusters impact the arms.
What can I use to keep my implements in check when using them?
Chains or something else?
Thanks for the help.
(quoted from post at 09:03:23 04/25/21)
I'm a little dense before coffee. It's BH 3222 not a CB75. If that even makes a difference.
Some pictures of what you have may help. To me this is one that will be hard to figure out without seeing it. Even then it will likely need to be hands on trial and error on your part.
Your problem will be finding somewhere in line with the lift arm pivot point to mount anything internal. The
other problem with internally mounted check chains will be interference with the pto shaft of any mounted
equipment that uses one.
