175 Massey clutch
FarmerWes76
Just recently had a new clutch installed on my Massey 175, and now it seems to be slipping and clutch doesn't catch till the top of the pedal.
Have only used the tractor around 100hrs give or take. Only work it has done is moving round bales and some hay raking. Any help would appreciate.
Had it replaced Then I'd go to where you had the work done and ask about it. I have a 175 with the two stage clutch and it worked perfectly when I replaced it. The only adjustments was clutch pedal and one on the clutch itself for the pto clearances.
looking thru the plate hole under the clutch, make sure the three small bolts that hold the pressure plate off the discs were removed. I've seen two instances
where they were not and the tractor actually worked for a while.
