175 question
kevinnbama
i posted a question on here a few weeks a go and got some good help but need some more now i have pulled the tractor apart now and the clutch if fin pulled the shifter plate off and dont see nothing broke in there i can turn my pto shaft and only one gear turns nothing in the back turns but i can trun the saft on the back of the tractor and see the saft and pump turning inside could it be something broke in the gear box ?
sorry yall may need to know the troule first the pto quit and the lift arms will not move wa cuting with bush hog and drive line came loose and hit lift arm and quit working
Reading between the lines here, I gather that the drive hub of the PTO plate is intact. If you can turn the transmission PTO input shaft by hand and "see" only one gear rotating, I gather you must have the steering box removed from the transmission.
If the PTO shaft at the rear of the tractor is turned, you should be able to see the lower driven PTO gear turning , it's the one below the front gear,(that's turning), in the front of the transmission.
If it is not turning, a failure has occurred somewhere between the lower transmission PTO shaft and the hydraulic pump shaft. Decide where the failure may be from turning the input and output shafts, and you may find that a shaft or coupler may be the problem.
Separation of the tractor between the transmission and the rear centre housing will probably be necessary.
See how you go,
Evan.
