I hope someone can confirm what I'm thinking. I was going down the road traveling in road gear from one field to
another, half way down the road, the engine starting to come under an extreme load, I engaged the clutch, and the rear
tires skidded to a stop. Now, the tractor will not move if in gears 3,5,6 or R2 (lower tier pattern of the shifting
pattern)it will put engine under an extreme load and stall if you let it, however, if I move the gear shift up to the
first tier shifting pattern , gears 1,2,4 or R1 they all work and the tractor functions fine, even the hydro works fine
in all 3 positions. There is no grinding or odd noises going on that I can hear... I think I have some galling going on
in the transmission, where gears are interfering with each other, and locking up. Am I all wet or what do you guys think
my issue is. All fluid levels are full, there seems to be no burning smell in the oil, or discoloration. Any insight
would greatly be appreciated!
